2-3 place enclosed trailer
So I am starting to look for a enclosed trailer. What length or dimensions do I need to be concerned with to have a 2 place, but be able to haul 3 if I want? Don't really need or want a huge long 4 place to park!
I have a 7-23 all aluminum enclosed, that pulls really easy. It will hold 2 long tracks one behind the other, plus alot of gear. If you want to put 3 long tracks in it, they work best in backwards and staggered, all facing the rear door. With this setup you still have plenty of room for gear.
I have an 8' by 18'. 14' box with a 4' V. Works good for 2 and 3 can be put in with the center front facing forward, and the two rear facing the rear door. If the sleds have reverse, they back up the ramp pretty well. I think it would fit a 151" in the center and 151-159 on each side.
So far, I have only hauled 2 144's and 1 155 in it and it still has room for gear tubs and fuel jugs. I took the 2 144's, 1 136 and the X120, gear tubs and boxes of Xmas stuff to McCall last winter. Glad I had the room, yet it is small enough to not feel too much bigger than an enclosed 2 place.
VB
8 x 20 is the perfect length.... you can haul 3 longtracks easily without a shoehorn to get them in and still have room for gear.
I have a 20' Charmac (15 square + 5 V) I can fit 3 162's in it. I pull them in from the front and drive them out the back. Even if I am only hauling 2 I still pull them in from the front. I like that I do not have to worry about dragging the side of the hood on the side of the front door.
I have the same size trailer and love it! The 7' wide tow nice and easy!
