1m 900 throttle response not there
2004 1m 900 efi 151 long track all stock except for a slp can. problem, starts fine idles fine, but give it a blip and it trys to die out (while idling). it will open up and go strong, but as soon as you let off the throttle it boggs/hesitate then it will come on strong again. if you go wot then come to a stop it will idle rough and sometimes die. I changed plugs filled with good fuel & isoprop., cleaned the power valves, checked the reeds & throttle body. it ran great last season. summerized pulled plugs put teaspoon of inject. oil, fogged throttle body, drained 98% of fuel and put stable in fuel that was left in tank. info would be apreciated thanks
switch on throttle
I have heard of issues with the switch behind the throttle (little black button). Im not sure if it will help but unplug the wires going to your throttle block im not sure what it will do with an efi but it could help.
