C
1973SR is a 643 chassis; rear close off panel, full length reproduction seat; SM292 gas tank; Phazer skid; Kimpex "R" track; original steering post and bar, but they are bent and have a hoop for ovals; steering hoop is not original as I had to replace it; Phazer chain case with hydraulic break; Label X pipe; aluminum lube tank mounted on tunnel right rear; lube system is pressurized by exhaust-no pump or gravity feed; GPX spindles; Northstar Ski's; original bumper and hood hinges; GP292 bottom end; SM292 welded-trued-balanced-polished crank; GPX bell housing; GPX recoil; MSD ignition; SR292 cylinder-stock; ZRT600 reed cage; 44mm round slide; SR292 head; ISR legal clutch guard......... comes with a Spare piston (Phazer); several NOS head gaskets; gears, chains (single row gears/chains); Computer cable for MSD and dyno sheet
I did not race this sled during the 2010 season. Fresh re-plated Nickel Silicon Carbide (NiCOM) cylinder and a NOS Wiesco Piston and rings
This is a turn key racer
$6500
![SR292 right underhood Ebay.jpg SR292 right underhood Ebay.jpg](https://www.snowest.com/forum/data/attachments/86/86707-60aee4654c434f711cb318754022d428.jpg)
$6500
![SR292 front view ebay.jpg SR292 front view ebay.jpg](https://www.snowest.com/forum/data/attachments/86/86690-6a6a377ce95ad98421f2d51c0d53690f.jpg)
![SR292 left rear view Ebay.jpg SR292 left rear view Ebay.jpg](https://www.snowest.com/forum/data/attachments/86/86696-a738db9e78cc0fcfd98893ffb4d7945a.jpg)
![SR292 right side Ebay.JPG SR292 right side Ebay.JPG](https://www.snowest.com/forum/data/attachments/86/86701-0997ca643c0eff8cc1ebff5a101c8c26.jpg)
