16x144x2.25
Modmxz
Can anyone tell me if an '07 takeoff 16x144x2.25 will fit my '02 summit? I'm wondering about the clearance for the longer lugs as well as width? Has anyone done it and what does it entail? Thanks.
Dan
I Have A 2003 800ho Summit Just Finished Putting A 151 16 Wide On Mine. Put A Couple Of Washers In The Back To Spread Tunnel & Took Out L Shaped Steel Bracket In The Middle Of The Tunnel & Put In 1/8 Aluminum One Had To Grind Down A Couple Of Rivets & Got The 2 Head Bolts For The Chaincase Machined Down To Half Of The Thickness From A Customer Of Mine. Just Started It Up To Night For The First Time Seems To Be Ok. Hope This Helps.
Don
2.25 for 2002 Summit
You may need 8T Drivers to fit a 2.25"
