16 wide track
It is very possible but there is kinda of alot to it.It wont just go right under them. Consider rolled chaincase, in my case i have generic holz rolled chaincase which isnt quite enuf clearance on front cooler so i had to rid of it and get a u cooler but i also have 2.5" track that is where i found problems, if you have a shorter lug length you should be fine, just make sure the track is aligned with the idlers, be exact as i spaced them to where they rub the inside nubs this will keep the track from walking side to side but beware so still dont have much clearance GOOD LUCK
