SNO DARTIN
COUPLE OF THINGS TO CHECK ON YOUR TS SKI
if you have the half pipe type of skeg in the center of the ski, hard snow,ice , pavement, they dart and and twitch and basiclly are second class steering units/skis
better is to install the three carbide rail center skeg sold and advertised on this forum, works much better
when your bike is sitting on a flat concrete floor, take a rafter square and with short side on the floor the the exposed edge on the square centered on the bolt that hold the ski on, the rafter edge should be 2-3" behind the front axle bolt, and It won't be on your KTM, but needs to be............this makes a lot of difference in the ski tracking straight and not darting. To fix this you either drill new holes in the ears of the ski pedestal and swing the ski back, or many have have good luck redrilling the bolt holes in the cnc machined block that hold the ski to the spindle, move the block back
this ski moved back is the biggest difference you can make to this TS ski to improve ride and handling.
when you have done both of these mods, the new ARO ski will still work way better..........$500 ?
if you live in Missoula Mt you can stop by and try any one of the three skis with these mods in the shop that are sitting idle and prove to yourself these are improvements possible.
