a little stumped on this one , it started fine in the trailer let it run for a while it smoked pretty bad but nothing un ordinary from setting all summer. a couple days later went out stared it was idling fine for a min then it died, started it back up and pulled it out of the trailer and into the shop and a puddle 2 feet around of oil and fuel on m y shop floor sled wouldnt idle, i fiured it was just loaded up and just needed to be run and burned out. so i went on doing some maintence and preseason work, replaced the reeds fuel filter and plugs pulled the sled out jacked it up ad run it several times now it will kinda idle when cold but not at all when warm, i have checked the tps setting it has not changed since new stil at .70 base and .94 idle checked the tss and throttle free play fuel ressure a little over 60 psi, copression is 130 on both sdes, drained all fuel and put new fresh fuel in it, reeds are brand new, what am i missing here it doesnt just die like the kill switch it slowly drops rpm till it dies
