Hi, my brother bought a used -13 couple years ago. Have not been used alot the last couple of years, But this season im forsced to use it.
I'm noticing it cant pull RPM past 7700-7800 on hard pack trial riding. It feels really sluggish, and not as crisp as i remember they used to be. I suspect there is some problem with the engine more so then with the clutches..
Dont know how many miles it got, because the display is bugged
Driving at sealevel
What i have Checked:
- primary clutch; weights was full of rust and was aftermarket adjustable 70g
cleaned it up and put in some 10-68 weight's
-Had stock spring
-Throttle wire is fine
- Checked one exhaust valve and it was clean and did not need to service it.
- new pluggs
-115 PSi compression test on each sylinder, one was slightly lower then other.
- belt deflection is good.
- belt looks good but dont know how old or used it is
I dont know if the exhaust valves works as intedned, how do i check the system?
I will try a new primary spring, and also check secondary, but my senses are that the engine is not operationg properly.
What can i check and tune before i by new pistons?
Driving at sealevel
-Had stock spring
- new pluggs
