Re: Belt issue
Check parallelism, center to center distance, offset & deflection. This has been covered by Racin Station in another thread. Team Tied helps, too. The cat spec for C to C is 11.5", some like mine are measuring 11 9/16". you can set the deflection on a trackstand so it barely creeps, or use a longer belt. The 1100T produces a bunch of heat, so venting is a must, & get the exhaust wrapped - Evolution powersports makes a header & turbo blanket that works well. They also have an intercooler fan that helps get air moving under the hood. Hope this helps.
