12 pro 800 with pc5 question?
I have just put on this pc5, with pa 13.6 head, slp pipe/can and was calibrating throttle with sled, it calibrates and sound clean on the stand when running.
min. 0.917 high. 3.798
So, my question is shouldn't my max voltage be higher?
It runs my mind it should be 4.??? max voltage?
It all seems to run just fine but am wondering if i'm leaving some performance out there?
using a 70-229 2012 stage 3 slp map
7-10k feet. ut.
Physically check that the throttle plates are actually opening all the way when the flipper is pinned. You may need throttle cable adjustments or flipper travel is limited from something like the grip or wires.
