Back to Polaris this year and first off GREAT SLED!! VERY Impressed so far coming off a 11' M8!
Questions
*Brake squeal sounds like brake is on when its not? Normal?
*Clutching or something else? Riding 9500+ Elevation
First ride- ran great 8000-8100 RPM's all day even with break in gas.
Second Ride- Would hit 8100 then drop down to 7800-7900
Third Ride- Put 60 Gram weights in Primary clutch hoping to get target RPM and Hold 8100-8200, Everything else is stock and no can. Beginning of day sled would hit 8200 and then fall off too 78-7900.
End of day seemed to be getting worse would not hit 8000 and hold only 7600-7700 RPM's
Is this normal? Do I need a softer primary spring? ( has stock black in now) I was expecting sled to improve as it got broke in.
Checked:
Track Tension
Chain Tension
Belt Deflection
Primary spring looks good and belt looks good
Have not changed plugs (Issue?)
Currently have around 100 miles and ten hours
Any input on this would be great not very familiar with Polaris yet! Thanks!
Questions
Checked:
Track Tension
Chain Tension
Belt Deflection
