11pro with mid bog and now A65code
T
Tony skagen
So I starting getting a mid range Intermittent bog today,then when I pulled it out of the trailer to put it away it it started flashing A65 on the gauge with a check engine light also would barely idle. Was thinking the bog was a tps but now I'm thinking injector. Did a compression test and it's good 125 each. 1100 miles on this motor! Any ideas on that code?? Thanks
So no one knows what the A65 code is?? I dropped the sled of at the dealer and had them scan it,the only stored code was for throttle switch and they also had never heard of the A65.
Here is the procedure and list of codes from the service manual.
Okay so the dealer called me and said they found that my gauge cluster is bad and that's what's causing the code! It's hard for me to believe that the gauge would cause a run ability issue. Has anyone else heard of this?
