1100T wont start
quick rundown 2012 HCR 1100T with EVO SC Kit, I took the machine down this summer to go through it, pulled motor etc, ordered parts throughout the fall and have re assembled the machine, now I can't get it to start, New battery installed, gauge comes on everything lights up like it should, go to turn key and nothing, I have spent the last 3 days on and off fawking with it and nothing. I have checked all grounds, replaced starter sensor, I have power to the starter the ecu is flashing code 9 camshaft sensor and code 19 crankshaft sensor. changed out the rov and went back stock tether and nothing. Im asking for any help or direction would be greatly appreciated thx in advance.
BD
Check connectors & harness
Check your cam sensor and crank sensor connectors and harness - sounds like you have an open circuit. Double check starter solenoid connections on battery - quite common to have these reversed. You'll have power, but no cranking ability. Did the machine turn over at any point? I'm presuming you did head studs, etc...
were is the crank sensor located??, cam sensor i pulled out wiped the end re installed. agree I have left something open and can't find…..I will go switch starter solenoid, no machine has not turned over since i put in shop in may. did head stubs last year no issues. thx bud I will go check out those mentioned.
