T
Turbo11T
Roll the windows down. . .
Haha. Now to business. The hood on the 1100t is heavy and the air intake setup while good is alot of the weight. The hood offers zero venting other than to the intercooler. The side panels have far to little venting as well. So thats the problem.
Here is my solution to the problem.
Center hood section for 1100NA. I will cut out the intercooler vent area so it is the same as the 1100t hood. I am going to port the crap out of it. There is alot of area that is covered by the shiny plastics on the hood that could have a million holes in it. Removing the headlight(cut weight) and going to use that area for the air intake. I am going to remove the stock air intakes on the bottom of the upper plenum(cut weight). The underside air intake will be gone(cut weight). Holes all over the place on the center hood covered in vents. The bottom line is heat rises so why not vent the top of the hot box. I may put a few vents on the side panels but honestly I think vents in the side panels make them weak and really get abused and look like crap in a short time fromm trees. Will still be able to do a windshield I like the two pc one that Skinz showed with there hood. It looks sporty. I obviously could save a few more lbs without some of the detail but I really like the lines on the hood of my sled and want to keep that look.
Here are some pics. I just got the center section today so I have not done much other than fit it up. The center section for the 1100NA is about $90-$110 from cat. It weighs like 4-5lbs. I am not sure how much the skinz hood weighs but I would think for $500 it better be light.
