L
littleredstroker
I bought a 11 rmk a while back, and I am starting to mess with the supsension a bit and have a couple of questions
Are shocks and springs all the same legth for the Rmks and the rmk pros?
Does anyone know of a set of springs that I can put in that are stiffer than the stock ones? I have about 3 inches of sag without being on it an get another 2 when I step on. Im probably 300# riding weight. The sled bottoms out way to much, and im not sure if its negativley affecting performance or not, but I cant imagine its helping at all.
Sway bar bushings, I went off a small drop , maybe 12 ft and when I landed both the plastic bushings snapped. I Remember reading threads about people removing the sway bar altogether but I rode last week removed and it was horrble on the trail... both front and rear springs are stiff as they can be so im guessing I just need heavier springs.
when setting up the suspension after ride height is set, what differences will softer/ harder spring setting make?
also the clickers from what I understand dont make it compress any slower, but controls how fast it returns, for example the clicker settings wont make a difference on it bottoming out on a jump or not correct ?
