Out of curiosity, does anyone know whether there is a potential for the Power Commander V to cut all signal to the injectors momentarily or is it designed to failsafe?
Couple things to check. Spark plug wires-- the internal wire will erode over time at both the coil and cap end. Typically unscrew and clip wire back a few mm so that you see good amount of wire strands. Also, pull boot off spark plug and look for carbon buildup on plug top-- indicative of a loose connection and ignition arcing on loose connection. Sometimes the built up carbon will allow ignition to momentarily ground on the carbon, leading to a feeling of ignition cutout-- similar to kill switch being hit.
Have you had the sled out this year yet to verify proper runnability?
Murph's post (not trying to swell his already swollen head) lends a lot of merit. These sleds are hard on plug wires and boots. This is what it really sounds like is/was happening. I've used the SLP replacements. Keep a set in the truck and on trips.
Even though you've replaced injectors, I wouldn't throw this out as a possible cause. The injector placement in this motor lends the injector to developing carbon deposits. Ultrasonic cleaning by a shop like Dr. Injector is what I used to do but I started using a bottle of Chevron Techron added to a fresh tank of fuel and have solved 4-5 sleds with that trick. Used to use it all of the time for engine runnability issues in the automotive industry before I made a career change.
Highly Rec a BR9EYA plug.
Finding wire problems in the TPS connector requires taking the connector apart. Not saying your test wasn't diligent but these can be difficult to replicate in the shop (wiggle test)
So I just had almost the same exact issue with about the same setup as you and I replaces everything, and it finally came down to my power commander was junk, was sticking my pto side injector wide open:
No codes
I have the same problem on my 2012. Do you find that it happens more often whe it's warm out? Mine is so bad when it's above my guess 32f out that you can't hardly even ride it. If it's cold out I have very few problems other than if you sit for a short time and let it soak up heat. It will clear up then if you start riding it in the cold.
Merlin, just to be clear. My sled is stock other than the MBRP can on it. I have been having this problem for two years now. I do believe that it is temperature related, but what is doing it has me puzzled. I have been out 4 times this year and the last time out gave me the problems. The only thing different was the warmer temperatures.
Do you think it could be fuel vapor locking? I have packed snow down by the fuel rail and that seems to help.
Thanks for your help!
Amen brother...glad to see you got it fixed. Just goes to show we are all pi$$ing in the wind with these sleds when it comes to giving advice for runnability problems.
