11 pro fraying belts
Checked my motor mounts and both mag side mounts are vary worn. Motor moves up and down 1/4". Do I just replace the round puck? 1700 miles and these are toast.
Had the same problem, my torque arm was cracked and motor mounts were worn and cracked too. Polaris has a kit that comes with bolts and mounts but torque arm is separate. I installed a slp torque arm on front of motor as well and that should be a good fix.
After installing all new factory mounts and arm motor was stiffer but still moved a lot. After the slp arm it was solid. But I still have not ridden it as all my snow is being washed away by rain.
I had this problem on my 12 and i put a slp torque arm on and my problems went away still on my first belt this year. Went through 5 last year.
Where is the stock torque are? Pto side ? I odered a slp torque arm last week, I will pick up mounts today
The stock torque arm is located behind the primary on the intake side of case halves. Replace this at the same time as other mounts.
works great
75 miles yesterday with new motor mounts and a slp torque arm and it works great.
I was able to cut the strans off my old belt and ran it yesterday and it worked great, I highly recommend the SLP torque arm.
