1 Place trailer in CO
C
cokingcat
I rebuilt this trailer to keep but I have since changed my mind. I have only used it twice since the rebuild and see no point keeping. It’s really a great custom trailer for the following reasons-
It has new wood decking that’s ¾ thick and stained
Its 10’ feet long, which is great for long track sleds
It’s 4’ feet wide
It has a real tie down screw and bar which is included
I put a eye bolt in the back of the frame if you want to keep something time down which would keep something going forward on a sudden stop
It comes with a jack, and I added two steel plates for a mount which normally bend
I put the rear lights back 7” so your less likely to hit them when backing up
I also added two steel plates on the bottom of the frame past he lights so if the trailer tips you won’t bust off the lights
The lights and all the wiring are new and hand soldered
I also ran all the wire through plastic conduit so in the future you won’t ground out from rubbing
It comes with an extra tire mounted underneath
It takes a 1 7/8” in ball
All the bearings are new, and I put one new hub on to be safe
It a super light trailer to tow, turn around and store
It has new plastic runners to protect the wood from your skis and so you don’t run off the edge when loading
I made the surface flat for multi use, and the ease of loading/unloading anything, but it does not tilt
I am asking 500.00 and it comes with a clear title. Call or text me (Ross) with your questions at 970 318 6992. If you’re SeRiOuS come and check it out. No trades, I need the cash for a wedding. The ramp in the picture is not included.
