09 upgrade
anderson
alright going to bite the bullet and order the kit.
09 body kit does anybody know the part number for the kit?
Is there two kits on with bumper and one without?
Will the 09 consol fit right on my 06 rmk without much problem? I want to move handwarmers to the consol like the new style.
I will need the kit from polz to lock up the rider select to do this correct?
What is part number i need to order for this 09 consol?
Stirup vents are they easy to put on also and part number please?
Sorry to ask so many questions jut want to order all the right pieces and make it as simple as possible. And also what is everyones favorite handle bars?
Thanks
09 body kit does anybody know the part number for the kit? # 2876986
Is there two kits on with bumper and one without? YES, There are many bumper options...... Skinz and CoBe @ FasTrax to name a few.
Will the 09 consol fit right on my 06 rmk without much problem? YES, It lines up perfect using the below part numbered console. I want to move handwarmers to the consol like the new style.
I will need the kit from polz to lock up the rider select to do this correct? YES, contact via PM to order
What is part number i need to order for this 09 consol? # 2633519-070
Stirup vents are they easy to put on also and part number please? Stir up vents @ Mountain Fit Hoods
Sorry to ask so many questions jut want to order all the right pieces and make it as simple as possible. And also what is everyones favorite handle bars? I use stock with 5" riser.
Thanks
Answers in BOLD Red, clickable links in Blue..Hope this helps.
Also, a great source of info: Polaris Parts Finder
You can get the Body Kit / Cobe bumper combo from Curt at FasTrax. <---- What I put on my sled.
Michele (FreeAgent on SnoWest) has a great deal on the kit and a stock bumper.
Both are great to work with and really know their parts.
Here's a link to my 09 Plastics conversion. http://www.snowestonline.com/forum/showthread.php?t=223991
also...
what 09 center console are you trying to mod on...the one like mine in the pics from my signature for teh 05 900 build, or the dragon console...
if its like mine, thats the 07-09 IQ center console, but if you want to get the dragon console, you will need to modify it with the aluminum side shields and is alot more work...
i want the new style with the hand warmer switches on the consol
CONSOLE
# 2633665-070 ($111)
SWITCHES
# 4011319 ($18)/Handwarmer Switch
# 4012090 ($31)/Mode Switch
# 4012091 ($31) Headlight Switch
SIDE SHIELDS
# 1015643 ($98)
# 1015642 ($98)
its a sick mod, and will look great, but its very $$ for the conversion...unless you can get someone thats parting their sled out, buts its hard to find for sure...unless you hit up a swap meet ;)
and you better be good at wiring...lol..
If you want shock well vents it's a lot easier to install them while the panels are on your bench.
What do u mean? Will the new console fit the 06 tank?
you have to do your own part look up here...ive listed a ton already and have done it a bunch of times on this subject..
if you want to use the DRAGON style center console, you will have to convert to the aluminum side shields as well AND get rid of the factory rider select system...
if you want to the newer style IQ console (like i did on my 05 900 build thread in my sig) you will ONLY have to get rid of the rider select system and have a fixed steering post
BOTH of these center consoles will fit pretty close on the 05-06 fuel tank..there is a SMALL gap but very un-noticable
