Looking for some advice....I just added the BD intercooler to my TD8, I am running 100% race gas at 10 lbs boost (5000-8000 elev). I am running the BD starting numbers as they worked pretty well on PG before I added the intercooler. I am also using the BD controller and EBC. It seems to be lean above 5000 rpm at the mid to upper throttle position. I don't have an AFR gauge but it is cutting out like there is not sufficient fuel, EGT's are running 950-1125. Does anyone have experience with this setup and what is working for fuel / psi setting? Thought I would ask before making changes. Thanks.
