09 summit air intake
Having trouble with snow plugging air intake in deep pow. The other sleds I was riding with werent having troubles, but I was always stopping to brush off the air cleaner. I thought the 09's had fixed that from the 08's.
If the foam gets pushed in you run the possibility of water ingestion. I did this the other day with a piece of 12-2 wire.
There was a good topic awhile back where they drilled holes in the top and bottom of the intake and put long upolstry tabs in to hold the air filter from pushing in. I did it to mine and it works great. Ill try and get some pictures.
So the problem is the air cleaner is getting sucked in and letting snow by? I did see some other sleds with aftermarket intakes. Are these not needed if you keep the filter from getting sucked in?
they still get covered with snow--we run a slp cold air intake and a 2 1/2" florite in the top of the air box--
were in the top of the air box do you put the flow rite im have trouble with my 08 it has the slp intake and i have the foam air filter from an 09 behind the 08 screen last weekend in the big horns was a bit much for it the end of my second day it was actting up but so was half the sleds i was riding with
I use the intake screen from a M series cat, take a little time making a template to trace and cut out with a utility knife and/or ROTOZip. I've been trying to figure out how to attach pics-no such luck?
Mine would plug on the inside of the foam portion with snow because the cover did not fit right. i turfed the 09 filter and put in the 08 and modified as per Turboal and have never looked back. once and a while just give her a wipe with your glove and good to go.
next time i have the air box off i'll get a picture and do a post---
