09 RMK 700 is it my regulator
So I installed the updated regulator about a year ago,original was still fine.First ride of season the headlights go dim and no dash lights.Engine runs fine go's into reverse no flickering of lights or dash just a dim light.Any ideas? I tossed the original reg or I would put it back in too see if thats the problem.I also dried out the connections by the front of the hood hinge and still no luck.Seems like a bad ground.
my 2 cents
Does it make a difference hot or cold , does the sled always have these issues ?
I would suspect the volt reg if it fails or gets worse after running awhile and then works better when cooled down for awhile ?
