09 Nytro---A/C 162 suspension anyone using this set-up??
66chevy327
New member
as stated, what are the modifications done? been getting good info from KMOD(THANKS) are you using stock mounting locations? shimming the front, and cutting the rear mounts on the A/C skid? give some feedback. Thanks 66chevy327.
I have this exact setup on my sled. Running it with a CE. I like the way it works. My sled was stock otherwise last year when I put it on. I don't know how it will handle boost but that probably won't be this year anyway.
You have to shim the front about a quarter inch on each side. The mount moved up and forward about 1.75". The rear requires a new drop bracket. I used 1/4 aluminum plate to make mine and bent new running board braces out of 1/8 plate. I dropped about thirty pounds between the drop brackets and the skid.
May not be the most functional setup out there but I picked my skid up brand new for 500 bucks. After I add in the powdercoating to make it blue I am still only around 600. Not a bad way to go if you don't want to drop 1500-2000 on a skid.
Here are some pics of the install. I did have to shave the rear cross shaft about a 1/4 on each side. You can see in the pic how I moved the front mount. Most importantly the skid is at the powdercoater right now. Rails and all will be Yamaha blue this week!!!
