09 M8 weight?
A
ACM7
New member
Any one know what the 09 M8 Sno pro weight is? What about the 2010? I looked on there web site and could not find the weight.
the 2010 is about the same as 09 maybe 1-2 pounds lighter. The weight lost by the seat and crank is cancelled out by the suitcase of a can they put on there. Then the only difference might be the new skis.
If there is a 2# diff between 153 & 162 tracked machines, that must mean the 162" track weighs 36#. Wow!
enough guessing here:).wyoming t/a weights.
09 800 154 X 523#
09 M8 162 Snopro 543#
09 800 154 X 523#
With the 2010 the power will be higher and it lost some weight. lose the suitcase can and it will be right there with the XP but will be a lot more reliable!LOL:rolleyes:
with all the weights pretty close i think it comes down to rider ability like it should be. all the new sleds are great. i know im on the heavier of the sleds but ive taken some weight off mine and luckily i only weight 140 lbs so i have the weight advantage being 20 to 60 lbs lighter than the average rider. to bad my ability holds me back ha lets just go ride, oh sh!t ya its summer maybe we should just keep talkin trash...
fisrt its 440lbs and now your over 500lbs ? If you ever get pulled over for drinking don't say anything.
Was that 4 drinks or 9:beer;:beer;:beer;:beer;:beer;:beer;:beer;:beer;:beer;:D
those are the way we ride full of fluids weights.fox float fluid,cable lube,dust on the hood ect:).
wow.im starting to sound like wyoming t/a.:eek::eek:
The cat is only 20lbs heavier and its a 162 instead of comparing a 153 and 154. I thought the doo promotions said they were "way" lighter, it couldn't be doo using marketing tactics and lying..could it? They wouldn't do that sort of thing would they.
09 M8 153 Sp
At the Boise and SLC snow shows we pulled a 09 M8 sp 153 out of box threw a Snow check seat on it and it was 455 at both shows. The 2010 if you take suit case off will be 10-15Lb lighter. So out of box Boss seat and can should be around 440
