09 m8 turbo dead
sled died yesterday for some reason. suddenly started running like sh*t only on one cylinder then died and couldnt start it. came back tthis morning and it started 2nd pull but barely running on one cylinder. for the last 3 rides the guage and headlights would cut out and i couldnt get over 7200 rpm but otherwise ran fine. and one other thing that is really wierd is the rubber coating on the brake line is all melting off and melts to anything it touches. yes i checked if it melted any wires but no, just the casing:D 09 m8 with boondocker pump gas kit btw
i fiddled around with sled today. pulled the charge tube off and the air box had like half a litre of gas in it. held the flipper to the bar and pulled like 10 times and it sputtered to life all good again. a stream of gas came pouring out the exhaust. my guess is i leaned it out to much and tripped the det sensor which added more fuel which drowned it dead. does anyone know if tripping the sensor allows it to dump that much fuel?
could you have fouled the plug in the one cylinder and the fuel is from running it with a fouled plug??? i would try changing the plugs and see if it helps. am not a turbo guy but they say they have a lot of problems eating reeds, this could also be a place to check.
