Read with interest the posts on bearing failure in the 09 DD so I decided to take mine apart and have a look-see and found the dreaded and much talked about bad bearing, also the planetary set seems to be able to move around quite a bit in the nubs that hold it in place. I bought the sled used and it has always had a clunk shifting from rev-forward and forward-rev when you bring the revs up and engage the clutch. Is the noise that goes along with changing directions inherant to the new electric reverse? My 07 M8 isn't that way.
