Put the stock helix back in. Multi angle never seem to work that good for me. I have the same setup and it rips.
The MTX wieghts in my opinion are not worth the coin. When I put them in my M8 with the pipe kit I lost low end power, sled felt lazy. They would howerver take you right to the top and hold realy well.
Jason
Stock 68G cat weights also felt real lazy in my 09 M8 with the slp pipe. Went back to the 70G cat weights with a 125/340 speedwerx H5 primary spring and it pulls hard, way harder than the 68's even in a climb. Rode yesterday at 9K and was getting 8000rpm in a hard pull. I would go with 70's and 340 finish rate on primary spring.
I agree,
I put the the SLP 140/340 spring in and went up 2 grams on the primary. Sled now pulls hard all the way though from 4000-8150. I am still running the 46/36 Helix but I am at 0-3000 Ft.
Jason
What weights are you running?
put slp pipe on with their clutching specs-71g mtx with 40-36 helix. I ride at 9000ft and higher. Does not pull any harder than stock. In fact I lost low end snap. low end is more sluggish than stock set up. cluthcing help needed.
I have this exact same setup on my 07 M8. My tach says im still only pullin 7850. Like I said, im runnin the 40/36 helix with the 71g mtx with 3g in the heel and 1g in the tip. I also installed a shift assist. I would like to see 8000 on my tach but im not sure what direction to go. It pulls pretty good but as the OP stated, just dont seem much better than stock. Would goin back to the 36* helix be best? The reason i went with the 40/36 is for the 3700 rpm engagement, with the 36* helix i was gettin a 4100 rpm engagement, but i never took it to the mountain with the 36* helix in. The other option i have is to run without any weight in the tip and leave the 3g's in the heels. This is all for 3000-7000ft elevation.Sorry if it seems like im stealin the thread, just have this same problem and want to figure it out.
Add me to the mix too guys.
I now have my 09 M8 153" Sno Pro in the shop and it has a dealer installed SLP single.
The helix is a BDX 42/36 with the stock orange spring. I ordered a shift assist kit for it but, it isn't here yet.
The primary spring is stock and it is still set up with the 73 gram stock weights but, that seems rather heavy to me for my 3-7,000 feet elevation, right?
Should I try to get a set of 68 or 70 gram weights to try next?
Thanks, I was going to ask about grinding the weights but, where should the weight be ground from?
Can I install the shift assist in my shop or should I have the dealer install it?
Thanks bighoe, just got a couple more questions. Like I said, i have the heels loaded with the 3g rivets right now so if i dont take anymore outta the tip but instead out of the heel, am i going to see an increase in top end RPM's or will i be working backwards? The last thing is, Ive been thinkin about goin to a torsional secondary setup but ive heard fairly mixed reviews on them. Would i see some better performance if i swapped over? Thanks again.
