09 m8 bogging?
hey guys I went to valemount the other day and my sled started to act up near the end of the day and today I took it out playing in some ditches but its worse than before, it bogs a lot and im not sure why? I changed all my plugs before the season started so the maybe have 200 kms on them and I only have a d&d can on it. Not even sure where to start. it bogs when I give it full throttle and it will continue to do that once in a while then it will clear up after a bit of ripping, then I shut it down start it up and back to bogging. And when I start it now sometimes it wont start and it never has done that before?? whats going on, out of no where..
Throttle safety switch..?
Does it sound like its hitting a rev limiter?
Or does it almost die when it bogs?
it almost shuts off when it bogs and im at a slower speed. whats the throttle safety switch? any way to test that? I was going to check my plugs tomorrow too. doesn't sound like a rev limiter I don't think...?
well I think I got it cleared up, what I did was drained the tank of fuel I had in it topped it up with the stuff I usually get (husky 94 octane) and changed the plugs, seems to have worked. When I took it out yesterday it did bog very slightly from a almost dead stop 5km/h or so and I crack the throttle it would bog and die if I didn't baby the throttle. but near the end of my rip yesterday (45kms) it never did it at all and before it would do it when I was wide open and going pretty fast. So I guess I must have put some bad gas in it from valemount on the weekend..
I did end up checking my clutches and ground wires, needed to re ground 1 wire and I also found that my intake openings were full of ice and barely getting any air flow, must have been from the deep pow in valemount plugging it up.
Thanks guys!
