'09 M8 and SLP pipe installation
Soccerd6
how do you get to the screws on the bottem inside of the Y piece???? none of my allen wrenches can get straight on them... ???
I just bought an allen wrench that was the right size, and then cut it down with a hack saw. Then use a small wrench to turn the cut down allen wrench....Its slow but it works great.
I got a 1/4" ratchet wrench and found a bit to fit the bolts and did it that way. Worked well for me.
I used an impact driver to get them in as far as i could then shortened up the short end of an all wrench and tightened them the rest of the way.
I left the two lower inside studs in place and used the stock nuts. You will have to grind the outside edge off of the nuts to get them to fit. Works good, with no leaks.
Use a 6" ball end allen, cut the 90 degree bend off then use a #6 socket and extension to turn it.
