09 M1000T need help
Catman 42
The sled will only run if I squirt fuel in the throttle bodies. Have the injectors wired to stock (no fuel control in line) Have replaced ecu, have fuel pressure unplugged the hood harness, checked the injector wires for damage.
Any suggestions would be appreciated.
Thanks
Broken reed pedal, bad fuel pump. what kit you got I had a bad relay on mine for the fuel pump and mine would not start changed it out and wala easy to see if you have a fuel pressure gage.
Works now
Waited acouple of days tried it again and it started and ran. Showing an ECU code 17 so I installed a new sensor and hooked the fuel controller back up and seems to be fine.
I should mention that when this trouble started we accidentaly started the sled with the sensor unplugged
