I want to start a thread that only list problems and solutions on the 09 m1000, please keep it to the point and on track for future reference.
So far What I've heard- Most of these problems are rare and should not be worried about just something to consider.
1)Power Claw fray from rivets on tunnel / drill rivet and replace with shorter or put rivets in from other direction.-track fray thread, give information -
http://www.snowest.com/forum/showthread.php?t=118255
2)Bog,To much oil from factory / had to be turned way down to get to stock setting, oil adjustment threads -
http://www.snowest.com/forum/showthread.php?t=116678
http://www.snowest.com/forum/showthread.php?t=118967
3)One that overheated / NA -seized water pump shaft, hoping for full engine warranty?
thread-- http://www.snowest.com/forum/showthread.php?t=117978
4)Gas leakage, Recall / see dealer.-
5)Weak A-arm mount, ripping out / Easy fix.......... SKU: 4606-402 -Brace, Lower A-Arm $2.63
6) The tunnel is weak behind the rear stirrup. If you come down on the rear at all this section of the tunnel ext. will buckle.. / NA, maybe an after market company will create a brace to fix problem but for now be careful.
7) Fuel pressure #'s are not consistent / regulator and gauge - any one know of an actual # to run
8) belt life / Can't say much about this because there are to many variables, start with this, check alignment, put in extra venting, proper break in, here is a thread on belts
http://www.snowest.com/forum/showthread.php?t=115890
9) Steering post-adjustable / make sure lock nut for steering post is tight, its under the sled on the bottom of the steering post, standard post is weaker than last year.
thread link - http://www.snowest.com/forum/showthread.php?t=116012
10) High fax gets caught in track windows when backing down ramps, Issue is due to 2 wheel kit / Beveled rear of each highfax with dye grinder approx 45 degrees.
11) Pipe sensor fell apart inside pipe / Get Warrantied
Thread http://www.snowest.com/forum/showthread.php?t=121650
12) Oil pump sticking and not returning using more oil than needed.
13) metal shim under helix coming apart-recall is out see your dealer./ Get warrantied
14) a few piston scuffs not sure why- looks like cold seize, possibly a tolerance issue
If you add something to one of these please refer to by number, and if adding something please continue to number. post pic to for problems and solutions
