09 dragon turbo for sale has aprox 1100 miles been turboed since new,,, if you dont like the graphics they peel right off!!
If you add up the parts alone you could part the sled out and still make out!!!all the stock parts go with it!!
MAKE an OFFER
OVS race gas kit with 2871 garrett,, been running 13-18 psi on 50% race ,,can also be turned down for av gas or way down to pump gas
OVS race pipe and modified stock pipe to Kurt williamson specs not just a rear flange ,,, diff stinger and head pipe length!
HKS blow off
Full clutching including TEAM TIED secondary, both balanced and blue printed
Aem 02 and bosh boost guage buit into dash KOSO charge temp guage
Teather switch
aeromotove rising rate fuel pressure reg
powerclaw track with slp drivers
Timbersled rear with ice age rails powder coated white 155 inch
Anti stab kit on rails
Timbersled front suspension powder coated white with RydeFX air 2.0s
Arctifx graphic kit
Fastrax billit throttle block
Better boards Black
RSI 12 inch risers
RSI race bar
RSI high heat bar heaters
gas rack
SLP-- SLT skis black with red loops
Full venting ,,Hood ,Side panels,Knee vents
Float skid plate
This sled if fully tuned Fueling/suspension/clutching for 8-12K and needs nothing,, it had the latest pistons installed but there was no sign of cylinder wear or piston scuffing this motor has never been down because I install a new Voltage regulator at the beginning of each season,, ECU has the original 09 flash,The sled is currently in the snowies and will be there till the 30 of april you can come test ride as I will be there on the 26th -30th for my last ride this season Call me 847-774-9552 Jim $10,500 Keeping tunnel bag and bar bag and front floats unless you want the floats EVOLX $800If it doesnt sell I will be parting this thing out this summer !!!!!more pic when I did the build
http://www.snowestonline.com/forum/showthread.php?t=159545&highlight=KAWGRN
![IMG_6402.jpg IMG_6402.jpg](https://www.snowest.com/forum/data/attachments/105/105274-af41a5065aa3ddc56593ed6cc06d2f66.jpg?hash=r0GlBlqj3c)
MAKE an OFFER
HKS blow off
Teather switch
Arctifx graphic kit
Better boards Black
RSI 12 inch risers
RSI race bar
gas rack
Float skid plate
![IMG_7479.jpg IMG_7479.jpg](https://www.snowest.com/forum/data/attachments/105/105241-356fbd0f4cddbf040ba767225e4c58ca.jpg?hash=NW-9D0zdvw)
![IMG_0806.jpg IMG_0806.jpg](https://www.snowest.com/forum/data/attachments/105/105248-6b0177c283ebe8cd1ce61ea10ee5885f.jpg?hash=awF3woPr6M)
![IMG_7807.jpg IMG_7807.jpg](https://www.snowest.com/forum/data/attachments/105/105262-a91dc906a14b5174d09d38d0efa10a61.jpg?hash=qR3JBqFLUX)
![IMG_2767.jpg IMG_2767.jpg](https://www.snowest.com/forum/data/attachments/105/105271-749313ffead146bcdc405b73bf0d2c9d.jpg?hash=dJMT_-rRRr)
