09 dragon bogging down
P
poledge800
i have an 09 dragon sled is stock except for a can went out yesterday in about 2 feet of fresh snow and when i would play around on the open meadows it would bog out like it was way to rich so i would clean the snow off the hood and around the intake and it still do it, but when it wouldnt do it it ran awsome if i went to play on hills it would quit bogging and start pulling full rpms flawlessly i thought maybe it was exhauat valves, so i pulled them and the diaphrams are fine I'm running the orange springs
could it be that one injector is failing i have a boondocker efi controlbox on it and when i go to the injecter working cycle the pto side is always two numbers higher like 52/50 or 50/48 are the number that i have seen most
seal up around the headlite and the headlite adjuster, then install a set of slp powder valves...should run fine in over the hood snow then...
