P
I took it out of the trailer and tried to restart it with out any luck. It will run anywhere from 1-5 seconds before it dies. I tested to TPS and found the voltage is right on spec, tested the capacitor, it's ok. Replace the spark plugs and checked the compression ok over 125psi fuel pressure is 60 psi with good volume, disabled both the kill switch and key switch, ohmed out to stator,ok. The swapped out a known good voltage reg still no change. Any input will be greatly appreciated.
