09 D8 track swap questions
I will be changing my track tomorrow night, and would like some tips. I have only changed a cat track before, so i need to know what I have to do with the chain-case.
I know how to get the skid, and secondary off, after that, any tips or pointers would be very helpful.
once you have the skid and secondary off just pop the three nuts that hold the speedo sensor/pto side of drive shaft together and pull it out of the way, with the stock track and drivers you can pull the drive shaft through the pto side hole to get the shaft out of the chain case, if you go to bigger drivers or another track like mine the power claw you then have to unbolt the chain case housing to give yourself the clearance to put it back together. pretty easy painless process just take your time and make sure everything is loosened up before you pry
You will need beer and at least 2 friends to laugh at you when you get pi$$ed and start throwing parts. (Personal experience)
