09 crossfire 800, error code 1
Check Engine Light
(Crossfire/F-Series/
M-Series Models)
The Check Engine Light is controlled by the ECU and
may illuminate for a number of reasons. The light
should illuminate each time the key is turned to RUN
or START, and it should go out when the engine starts.
If the light stays illuminated or it illuminates while the
engine is running, the ECU is receiving input that is
outside of its established parameters.
Diagnostic Codes/
Check Engine
M-Series Models)
These diagnostic codes are flashed by the check engine
light incorporated within the speedometer/tachometer.
Refer to the following chart for diagnostic code
sequences.
NOTE: On single-digit codes (2, 4, etc.), the number
indicated will flash in an uninterrupted
sequence. On double-digit codes (1-2, 1-6, etc.), the
first number indicated will flash in an uninterrupted
sequence, there will be a short pause, and the second
sequence.
If the coolant temperature is at or above 80° C (176°
F), the coolant temperature light will flash a warning
(alert). If the coolant temperature is at or above 93° C
(200° F), the coolant temperature light will cease flashing
and will remain constantly illuminated.
Number of Flashes Trouble
1-2
(Check Engine Light)
Failure in ignition coil.
1-6
Incorrect adjustment/failure in
APV cable.
1-7
Failure in exhaust temperature
sensor.
1-8
Failure in servomotor.
2
Failure in injector(s).
2-1
Failure in knock sensor.
2-3
Failure in knock control system.
4
Open or short circuit in barometric
pressure sensor.
5
Open or short circuit in intake air
temperature sensor.
6
Open or short circuit in water
temperature sensor.
7
Open or short circuit in throttle
position sensor.
Steady Flash
(Coolant Temperature Light)
Coolant Temperature Above 80°
C (176° F).
Constant On
Coolant Temperature Above 93°
C (200° F).
m8majican, you are the all knowing god of the trouble codes!!! good for you taking the time to post them each time:)
lol...just copy and paste from my downloaded manual...keeps me from chopping wood and shoveling snow and taking out the garbage...the wife will delete my manual soon
