09 BD PG M8 A Little Boggy in the Middle and Horible on Gas
seth25
I'm running an 09 BD PG M8. Riding at 10,000 feet altitude. 1-2 gals on 112 with the rest 91. Saturday I was running 8.9 lbs boost with 88 duty cycle. It is a little boggy in the mid range. Around 4-5k rpm. My fuel pressure numbers are 17 36 50. My other numbers are all set at zero. I have no ADA and no EBC.
Should I try adjusting my 3000 and 5000 numbers down to the negatives to try and lean it up a bit, or lower the fuel pressure in the middle number? Plugs are nice and dark, maybe even a touch on the rich side.
Also, I am burning alot of gas. I am burning through about 3-4 gallons more than the others in my group. I know that turbos burn more fuel and my riding style is a factor as well, but 3-4 more gallons in a day of riding? Am I too rich, or is this normal?
BD starting numbers are very conservative (which is great don't get me wrong). It is not uncommon to lean out 5 to 10 numbers almost across the board. Once you get dialed you won't burn much more fuel than a stocker.
I would look at clutching before I leaned it out. I would check belt tension and put a new titanium spring in the drive. Maybe just a new belt will fix that problem sometimes.
on an 09 with the 010 pipe the numbers I run with an ada box are 3000 -5 -8 -8, 5000 -14 -14 -5, PSI 15 27 48 these numbers have worked great for me most of the time. but on certain days I do have to go up or down a few numbers on my lo and md
I have a 2009 BD PG kit with the ADA and EBC and I have been experiencing the exact same issue ( apparently that doesn't help too much in this regard)
I did foul all 4 plugs last saturday
I then slowly started leaning it out and watching my EGT's, and was at 15 30 42 by the time I was back at the truck, and I was still just slightly rich it seemed ... it didn't cure the bog at that 5-5600 rpm range under 1-2 psi of boost, but it made it less.
I was riding 9-10k too, almost exact same conditions.
when I unload my sled and start it i turn my 3000 lo to -15 and my md to -12 then head down the trail, after about 5 mins of trail riding the sled is nice and warm and the pipe is hot, I can go back up on the numbers. I've ridden all day many times with the lean lo and md #'s with no problem, I just found that with the turbo pipe hot it had a bit better off idle response and pull when I richen back up.
