09 800 dragon gearing and clutching
D8rider
hey guys i want to set up my clutching and gearing..i do alot of backcountry boondocking and hillclimbing..i got my slp single pipe kit with primary clutch set up to slp spec..so i was wondering if anybody has changed their secondary springs or helix and their gearing any inputs would be awesome thanks for your time
Increasing your IQ
I went 19/42 gearing on my 09 D-8. The sticky link below has a lot of good info. Check out the IQ sticky at the top of the IQ page.
Gearing: We Need A Sticky for Gearing, thread started by MOWER800
Good luck,
akrevrider
The red/blk Team secondary spring works good. It is a 140/240 rate. A little bit softer off the start but a bit stiffer on the top. The 240lbs/" on top helps with the back shifting. The delrin 'sp?' (plastic washers) sold by Team & SLP are a good idea too. They give a slight increase in the spring rate & help eliminate the torsional coil binding
BTW the Red/Blk is very close to the stock Blk /Red @ 155/222
I am running 19/42 and put a helox in it that isn't as steep, But I have no idea what it is and its to much work to pull it off. 19/41 worked good, I have only ran it yesturday with the 19/42 and it seemed to pull hard but they all do after they skit all summer
