09 700 RMK 155 - RPM Question
Nemesis88
Just got a new, 0 mile, 09 700 RMK 155 last month. I have put a little over 100 miles on it now and have started to open her up a little. Saturday I was riding around home, 1,100 feet, and saw the sled consistently running at 8,400 rpm with a max of 8,600 rpm. Runs great, but these R's feel too high to me. Motor, clutching, and gearing wise the sled is completely stock with the exception of an MBRP can. I am running polaris 10-66 weights as called for in the owners manual. Are others seeing these rpm's? Any suggestions on if I should make a change to bring these down and if so, what change. Thanks ahead of time for your help!
Your dealer should have set it up for your riding altitude. The proper rpms should be 8200. My 600 rips really well and will occasionally hit as high as yours on the flats, but it pulls the right rpms when climbing. You don't want to go by the max rpm readout only.
The dealer left it set up as it came from the factory - 10-60's in it for 6,000 - 8,000 feet. I checked the owners manual which called for 10-66's at 0 - 2,000 feet, ordered, and installed them. I was ditch banging all day (20 feet is a hill around here) so have to idea what it pulls on a climb yet. Not heading west until February.
If you aren't doing a bunch of deep pow boondocking or climbing, you should really add 2 to 4 grams. For me, overreving a touch on the trail, makes for great rpms in the deep stuff.
skibreeze - That is what I was debating. I think I will get a set of 10-68's to try around here. I already have 10-56's, 10-58's (this is what the owner's manual calls for for the areas out west we ride), and 10-60's lined up for our trip out west. Might as well have a selection for around home too.
Pownar - Nope, the exact opposite. I am 6'2", 240 without gear. The cold ones keep getting in the way of my workout program. :beer;:)
My 09 700 RMK runs 8000RPMs max at 2000ft with 10-66 weights. Seems odd yours is hitting that high of RPMs,that motor makes peak HP and torque at 7900-8000RPMs as seen in the dyno below.
Dragon 700
EngSpd STPTrq STPPwr FulA-B BSFA-B TsTim2 Air1+2 FuelP A/FA-B
RPM Clb-ft CHp lb/hr lb/hph second scfm psig Ratio
4900 57.4 53.6 41.7 0.8 0 152 59.5 16.71
5000 59.4 56.6 42.3 0.77 0.9 155 59.4 16.73
5100 59.6 57.9 42.9 0.76 1.3 154 59.4 16.49
5200 62.1 61.3 44.4 0.74 2.1 152 59.4 15.72
5300 63.4 64.1 44.8 0.72 2.7 154 59.4 15.78
5400 65.8 67.6 46.2 0.71 3.3 155 59.3 15.41
5500 67.7 70.9 47.4 0.69 4.1 158 59.3 15.23
5600 68.9 73.5 48.6 0.68 4.8 159 59.2 14.95
5700 69.3 75.3 48.6 0.66 5.4 160 59.3 15.07
5800 71.7 79.2 49.3 0.64 6.1 161 59.3 14.92
5900 72.5 81.4 50.5 0.63 6.9 166 59.2 15.01
6000 72.9 83.3 51.7 0.64 7.3 166 59.2 14.67
6100 74.3 86.3 52.8 0.63 8.1 165 59.1 14.31
6200 75.3 88.9 53.8 0.62 8.9 166 59.1 14.11
6300 76.1 91.3 54.1 0.61 9.6 168 59.1 14.26
6400 76.4 93.1 53.6 0.59 9.9 171 59.1 14.65
6500 71.5 88.5 53.6 0.62 10.7 172 59.2 14.72
6600 71.3 89.7 54.1 0.62 10.8 172 59.2 14.55
6700 73.4 93.6 55.2 0.61 11.7 178 59.1 14.74
6800 74.5 96.5 56.7 0.61 11.8 178 59.1 14.41
6900 79.4 104.3 59.5 0.59 12.7 183 59.1 13.91
7000 79.8 106.4 61.8 0.61 13.1 184 59.1 13.61
7100 86.9 117.5 64.8 0.57 14.1 187 58.7 13.23
7200 88.9 121.9 67.7 0.57 14.8 190 58.6 12.83
7300 90.2 125.3 71.9 0.59 15.2 192 58.6 12.22
7400 92.4 130.2 74.6 0.59 16.1 194 58.6 11.94
7500 94.9 135.5 77.9 0.59 16.9 197 58.4 11.57
7600 94.9 137.3 80.3 0.59 17.3 199 58.3 11.35
7700 95.7 140.3 82.2 0.61 18.2 202 58.3 11.27
7800 96.5 143.4 83.2 0.59 19.3 204 58.2 11.21
7900 96.1 144.5 84.4 0.59 19.7 202 58.3 11.02
8000 95.3 145.2 84.7 0.59 20.5 205 58.3 11.08
8100 92.6 142.8 84.9 0.61 21.4 205 58.2 11.05
8200 89.1 139.1 85.6 0.63 22.1 203 58.3 10.87
Thanks for the info Sledmax, I am thinking I will try to run some 10-68's to bring the rpms down. We have a big storm coming in the next couple of days, 10-14", so I will see what it pulls in that stuff. Thanks for your help.
I ride 0-4000 with my 07d7. I run 64's with ported cylinders and a single pipe. It revs 8200-8400 and likes it. I was using the old button clutch, 19-42 gearing, 163x2.5 camoX. I did notice that I couldn't use the heavier weights with the button clutch, I could have easily used 66's with the Team.
