08 rmk oil pump spring
Anybody know where I can get an oil pump return spring for an 08 700 RMK? The dealer tells me they don't even have a p/n for it as it is part of the oil pump assembly.
You should try fasteners and fire equipment on international between c and old seward. They have a ton of different springs. They should be able to hook you up.
Tore into it and the wiring harness has slipped in between the lever and the body. Spring was still ok. I have it prewrapped a turn so it'll close off at idle. Figured it slipped off. Thanks for the replies.
