08 RMK 600 cfi problem
I
iowarmk
Hello
I have a issue with my 08 rmk 600. When sled is cold...sit over night outside....when first start it up...the check engine light comes on. If light is one...motor will not rev up more than like 7000 rpm...ride it about 15 minutes..light goes off...and sled will rev up to 8200 and run great all day for the most part. I did have one day last year that it died and was hard to get started again. Changed the plugs and that seemed to get it going again that time. Anythoughts on the engine light? I will go check it again....I know the lights blinked a seris of times...like it was giving a code. I just can't remeber what they were...I want to say like 5 then 4 or 5 then 3. Any help would be great!!!
Thanks!
The 08 has a couple of recalls. One to do with the oil pump, the other with the handwarmers shorting out. Doesn't sound like it could effect your problem, but might be worth it to check it out. I have two of the 08's, not a single problem, though I just had the recalls done.
