Hi guys, I have a 08-m1000 snopro I just picked up used this year and the oil light will not go out. The guage also flashes "OIL." The oil tank is filled to the top and the float is not stuck. Is there any way of testing the oil sensor cable and/or the oil tank float assembly to see which is the culpret and eliminate the guage and wiring to the guage as the problem. Is the circuit normally open, ie. if I disconnect the sensor cable down by the tank, will the light go off? Will this create any problems if I leave it off for an extended period of time? Appreciate any insight into this as I would like to diagnose problem before I start buying and swapping parts.
