P
pleasesnow
I have the sled mentioned above and I run the 60 belt. I know that you can run the 46 which is much cheaper. Which belt is the better belt? Also, I am running 85g pins and anything over 3500' it will barely pull 7000 rpms. Around 2000' it will run right around 73-7400 rpms, and it runs awesome. Will the 46 belt raise the rpms? if not, should I put in 83g pin weights? I run anywhere from 1000' up to 4800'. Mostly 2-3000'. I have the rox rollers and put in a different helix.
