Was riding with friends last Friday and I have an intermittent bogging problem that has gotten worse than the prior ride (and did not exist before that).
Behavior: Wide open climbing or getting into it carving a sidehill, the engine sometimes acts like it is dropping one cylinder, or at least a half a cylinder, as it still pulls enough to let me turn out or cut a different sidehill path and feather the throttle some. This is happening more consistently now than it did last ride out, where it mainly only happened while racing a buddy across a short lake. I did find that when it does it if I feather in and out of the throttle I can usually get past it or get the sled to pull again sometimes all the way through the end of a climb. Straight out WFO from the bottom of the hill with a little run-up before the steep, and after 5-10 seconds - instant bog that won't go away unless you change throttle position. Does not die completely like I said, seems like maybe a 30-50% reduction in power. It is not an instant RPM drop so I do not suspect clutching, also because when the bog is absent it climbs like a champ.
I am not getting a check engine light flash (so probably no DET issue), not hitting the rev limiter (happens even way below 8000 RPM), water temps are fine, KOSO EGTs were showing in the 800-900 range one time that it happened for a prolonged time during an easy sidehill (did not feather the throttle which gave me plenty of time to check EGTs and check engine light). Max EGT shows a little over 1100 degrees F.
Sled details: Chassis has approx 4100 miles on it, engine has a lot less. Carls 860 big bore with pistons / rings replaced late winter for maintenance per Carls. Approx. 1500 on bottom end. Exhaust valves were cleaned and passages checked at that time. Reeds inspected at that time and are fine. Switched out spark plugs for a new set of BPR9EIX Iridium NGK (from a used set) during the ride, no difference. New spark plug caps before the ride, wires look good but are in the protective plastic loom cover stuff so difficult to inspect them completely.
Due to a no-start problems after the overhaul over a month ago, at that time I ended up switching out the stator (which did not help), complete engine harness with injectors (which did fix the problem), fuel pump tested fine at that time, new fuel filter was installed, VR switched out and back to "original" (replacement "good" one). No indication of voltage regulator problems i.e. no flickering of lights, voltage level on gauge is good / normal. I did switch out the gauge with an analog / digital combo gauge from an 05-06 900 but all the lights light up when you start it and it self-checks fine.
Ideas? Even though I did not get a CEL (chk engine light), could there be a code in the computer? I can ask the local Polaris dealer to read out any code.
- Seemed like the SPI fuel filter line was "kinked" on one end when given to me by the (non-Polaris) dealer, I mentioned it and they said "they all come that way". I was thinking poor packaging but at the time I was trying to get the sled just to fire up and was glad to find a filter locally. Maybe this is restricting fuel flow? But if it was, wouldn't I see EGTs spike, or have the DET sensor go off at least due to lean condition? I have another fuel filter without this kink I can put in there to test next ride out (possibly / probably last ride of the year).
- Plug wires - replace them too?
- Could it be a bad throttle position sensor, even though I am not getting a code?
- Maybe the stator I got has intermittent issue(s)? although it worked fine for a number of rides.
- Coils? Seems strange one would go out now but you never know (they were the only thing I did not change out when trying to get rid of the no-start condition after the new top end). I do have a friend who (I believe) has a spare set. Will see if I can get them and switch them out before the next ride (if it happens).
- Exhaust valve selenoid? Easy test - just plug it off...
P.S. Thanks to NapaMatt, sled_guy, PaulAnd, AngerManagement890, DiamondDave, and many others for giving me lots of good ideas when this sled would not start after the new top end (well, it started a number of times in the shop and on the trailer but was giving me a CEL injector issue blink code and finally would not restart at all). While annoying and sometimes dangerous, this problem is small in comparison to that one, at least I am riding.
