08 Dragon parting out, lots of good parts left.
If I'm out of line on prices, let me know, I want this stuff gone.
EDIT 18 Dec, if you don't see it listed, I don't have it.
complete bottom end w/ trashed lower rod bearing and cracked the bottom of the case, pto end is good, includes oil pump, water pump, magneto, $300
Head, includes, head cover, det and temp sensor $100
Throttle body boot $25
Stock bars with heaters, grips, mtn bar and throttle block . $150
Voltage regulator $50
Complete Brake Assy. Caliper and master Cyl. $75
throttle cable
Airbox $45
wire harness $60
Throttle bodies $100
gas tank $75 No pump
Oil tank $45
Chain Case $100
exhaust silencer stock $25
water pump $40
oil pump $30
2 Stators $90 each
1 scored monoblock $175
ignition switch and key $15
Hood wiring harness $20
Riser
![023-3.jpg](http://i122.photobucket.com/albums/o252/skibreeze/023-3.jpg)
![008-8.jpg](http://i122.photobucket.com/albums/o252/skibreeze/008-8.jpg)
![001-7.jpg](http://i122.photobucket.com/albums/o252/skibreeze/001-7.jpg)
throttle cable
![032-2.jpg](http://i122.photobucket.com/albums/o252/skibreeze/032-2.jpg)
Airbox $45
wire harness $60
![014-4.jpg](http://i122.photobucket.com/albums/o252/skibreeze/014-4.jpg)
![035-2.jpg](http://i122.photobucket.com/albums/o252/skibreeze/035-2.jpg)
Oil tank $45
![018-5.jpg](http://i122.photobucket.com/albums/o252/skibreeze/018-5.jpg)
Chain Case $100
![019-6.jpg](http://i122.photobucket.com/albums/o252/skibreeze/019-6.jpg)
water pump $40
oil pump $30
2 Stators $90 each
![016-4.jpg](http://i122.photobucket.com/albums/o252/skibreeze/016-4.jpg)
![017-4.jpg](http://i122.photobucket.com/albums/o252/skibreeze/017-4.jpg)
Riser
