A
I would really love some help with addressing this issue.
2008 Polaris Dragon 700 RMK 155.
I bought this as a second sled and the deal was to good to pass up. I immediately tore it down as it had 2,600 miles on it. I replaced the top end with weisco pistons and gasket kit, had a machine shop hone the cylinder slightly, installed v-force reeds, replaced exhaust bellows and springs, replaced the throttle body boot, new clutch weights and spring (SLP), new pipe and can (SLP), New HyperFax, found a broken LH throttle control with melted wires preventing lights from working... soldered it hard/direct to salvage.. seems fine. trying to explain all work incase of something simple or silly. I replaced the fuel filter, drained all oil and gas with a pump, replaced chain case gasket/oil and tightened, new plugs, new voltage regulator.
Upon completion of all this work, the sled fired strong and ran like a top. I did my three start and cool downs over the first 24 hours. I took it out and started my first ride and it started to bog when i punched it and noticed a light blinking once. Read on these threads it was a TPS, found that I missed plugging that wire back into the throttle bodies. Took it back out and no light and the sled ran like a fiery dragon. i put about four gallons of gas through it and took it to Haines, AK. i went through a couple more gallons on the flats and then took it for a big ride up into the mountains and started to attempt some full throttle sessions. it ran like a beast... upon my decent, halfway down in the trees, it just suddenly bogged and quit. I tried to start it, fired first pull and died. I pulled the plugs and changed them. let it cool for ten minutes. Pulled it and it fired and quit. pulled and pulled and pulled and nothing. Got towed down, unplugged all my wires and replugged. wiggled the fuel filter and injectors. pulled, it fired, and would barely idle. it would bog and die the second i touched the throttle. back in the shop now. upon checking all the wires again and shaking the fuel filter. it fires and seems to run fine, but bogs when i punch it. i can feather the gas and it will wind out. Anybody have any ideas what is going on here? plugged filter already? TPS? ECU? Grounding? It seems to have strong spark on both sides
