STATOR TESTING SPECS 2007-2008 800, 700 & 600 CFI
My 700 is now starting to cut out when riding. Happens at the end of the day when I get to 1/2 tank of gas. At 5200 rpm and about 38mph. it will act like it shuts off. I have to let up on the gas all the way then it will take off again. Any higher speeds it works okay. Took it to the dealer and spent $150.00 for a fuel filter and for them to tell me there is nothing wrong with it. They said there were no codes and the checked the tps base line and said it was okay. Still think it is the tps. Anyone have any ideas?
Real E-Z to test the stator, here's the specs:When the sled is acting up, did you/can you watch the voltmeter on the right side of the dash gauge and see if the voltage is dropping and/or fluctuating??????
Test the wires coming from the stator (+/- 15% at 20* C) w/sled cold, then repeat when warm:
For the 2008 600cfi/700/800 CFI's
1) YELLOW to YELLOW 0.13 OHMS
2) DARK GREEN/RED to GREEN/YELLOW 15 OHMS
3) DARK GREEN/RED to BROWN/WHITE 30 ohms
4) DARK BLUE/YELLOW to BLUE/YELLOW 2.4 ohms
5) WHITE/RED to WHITE 190 ohms
6) WHITE/DARK GREEN to DARK GREEN 190 ohms
7) BROWN /WHITE to GROUND 0 ohms
8) BROWN to GROUND 0 ohms
+/- 15% at 20* C
One more thought, how about taking an old oil pressure gauge, air gauge, whatever and temporarily hooking it up to the schraeder valve (on the fuel line, by using the old style A/C charge kit line available at auto parts stores) by the air box and temporarily mount (duct tape it/wire tie it, whatever it takes) the gauge to the handle bars so that you can monitor the fuel pressure as you're driving down the trail.
Mid to high 50's P.S.I;. is what you wan to see, whether it's idling or doing 100 m.p.h., 1/4 tank or full tank, maybe the fuel pickup line inside the tank is no longer on the bottom????????
Hope this helps[/QUOTE]
