Need some help here. I have a mid range stumble that just about makes the sled unrideable. It was into the dealer and they looked at a # of things, and all testing, including latest flash is a wash. You name it and it has been looked at. The sled was hitting 8200 on first past and then forward would hardly hold 7000 rpm. Worst, most tiring day of riding i have ever had with the constant threat of the motor falling off at the worst possible time. This is flatland riding at about 2000'
Today i stuck the factory mountain weights (62 g) in and the bulk of the stumble has been reduced. Everything is factory and they did try a different primary clutch when it was into the shop, that had flatland 68 g weights in and it did not change anything, rulling out a faulty clutch. Today, I could ride at 8200 rpm and the lighter weights, at this low elevation seemed to not overrev. SHould i try 60 or 58s to reduce the stumble further for flatland use. Does this lead any of you to any reasons why this is happening? Is the guide on weights that comes with the machine to be taken with a grain of salt? Do you see a overweighted machine bog terribly at the high rpm and not be able to hold max rpm properly. Help!!!!!!!!!!!
