08/09 Tail light wiring?
If i remember correctly white=ground, black=constant, red= brake
I am trying to go off of memory so if anyone else remembers better please chime in. I just used a test light to figure it out.
Are you using the SLP led tail light, if so the brown wire in existing tail light will need to be connected to black (Ground), the Blue wire (Brake light) will connect to red wire and the yellow (tail light) will connect to white wire. Good Luck!
