C
CF7SP
Hey guys, need some help. Took the first ride on my new to me 07 xrs in the UP. Here is the starting point: stock motor, hps can, 490 pto jet, 500 mag, middle needle clip, 17.5 pilots, goodwin clutching for low elevation.
Took the first burp down a field and sled felt doggy, and could only make it to 7500 rpms. Changed clickers, started at #3 and went to #4 with no change. Went to #6, no change still only holding about 7500 rpms. So decided to continue til we got back to the truck. Made it almost 8 miles and stuck a ring, took the primary and moved it right away back and forth, dumped oil down both cylinders and in the gas to try and free ring, but sled was still only running on one cylinder.
Got it tore apart tonight and found 140 psi for pto, 143 psi for mag. dpm hose disconnected. Got the ring to unstick obviously judging from the compression. However, still only like it is running on one cylinder. Carb boots and reeds seem to be ok, however did not take reeds out completely to inspect them.
So, what could this be? ECM? Cracked reeds? Crank? I am lost, please help fellas, wanna get this beast back on the snow. Another thing, I am not sure if this would make a difference, but I did change out the handwarmers to a 2-wire off a nytro, but only spliced the handwarmer wires and used a resistor off the stock taillight system. Not sure if this would have an effect or not. If anyone has an idea, please let me know. Thanks in advance and happy sledding!
